Suggestion on heads?
Hello all.
I am currently in the market for a new set of heads for my 351w. It has a mild cam in it (270/280, 448/472 - flat tappet) hooker comp. headers, stock ignition system for now, stock heads ('78 model 351), and a holley 650 double-pumper. As you can tell, it's still a daily driver. I'm just looking for something that will complement my setup and give me that bump in performance over the stock heads. Thanks for your suggestions! John T. |
AFR makes the best stuff out there for Ford as far as I am concerned. The 165cc heads would probably work pretty good on your motor. I have not been that impressed with the Edelbrock stuff. The World Products would be a good choice if you wanted to go with an iron head.
| All times are GMT -8. The time now is 10:10 AM. |
