-   -   ROCKERS CAME APART, NEEDLE BEARINGS IN OIL PAN (https://www.racingjunk.com/forums/showthread.php?t=23387)
motorobb625 03-09-2009 05:34 PM
I just bought this 427 small block that had 2 rockers broken off at the mount. (one of the rockers spilled all its needle bearings) most of them were laying on the head. I pulled the oil pan and did find a few in there along with some brass shavings. the motor runs great but is it safe to keep it going with out a complete tear down ?
hammertime 03-09-2009 05:53 PM
Re: ROCKERS CAME APART, NEEDLE BEARINGS IN OIL PAN
No way would I not pull it apart
TheYellaBrick 03-09-2009 06:29 PM
Metal shavings in oil pan equal shavings EVERYwhere.....Rip 'er apart....If everything looks good including the bearings, clean VERY well including a block dunk and screw it back together. These little things happen for a reason...you'll probably find something within that would have caused catastrophic engine failure anyway. At the very least you'll know EXACTLY what you have ! :D
I972Nova 03-09-2009 07:08 PM
Yep it sucks but you HAVE to pull it apart and make sure everything is ok. Throwin a new set of bearings and new gaskets is alot cheaper than tearing stuff up.
cepx111 03-09-2009 10:14 PM
Where did the brass come from?
zipper06 03-10-2009 04:09 PM
X2,
it might be from the distributor gear, but i would want to know for sure, pull it apart.
blowenstang 03-10-2009 07:25 PM
rip it apart to be safe
brass could of came from a seat or it might came from the
bushing around the wrist pin
blowenstang 03-10-2009 07:26 PM
come on cep your a race master
radicalz 03-12-2009 01:34 PM
I would not guess at what it went thru I'd be tearing it down to make sure ewverything is ok.... :wink: :wink:
motorobb625 03-15-2009 03:57 PM
bearings in oil pan update.
you guys were right ,I tore down the motor this weekend and discovered serious main bearing damage. Any idea what a machine shop will charge to dip the block, intsall cam bearings, and disassemble / and clean heads for? I have never done any thing this major to a motor before. Thanks for all your help!
