-   -   Tunnel rams (https://www.racingjunk.com/forums/showthread.php?t=23394)
showbusiness 03-10-2009 01:20 PM
Tunnel rams
Am interested in locating a tunnel ram to match up to a set chapman edelbrock raised port heads ,sbc Thanks
zipper06 03-10-2009 04:29 PM
You maybe able to use a std. tunnel ram with those heads. I had a similar problem fitting stacks injection on Brodix 10 RP's. I had to make 1/4" spacer for the top of the blk. between the blk and bottom of the manifold, and had to use the .120 tk intake gaskets to get the ports to line up. It's what worked for me.
showbusiness 03-11-2009 02:56 AM
Tunnel rams
Thanks for reply ,see lots of rams out there but nothing for a direct bolt on.
