-   -   Anybody done this, and (https://www.racingjunk.com/forums/showthread.php?t=23399)
zipper06 03-10-2009 04:05 PM
what was the solution???
O'k i've got a Dart lil "M" 350 mains, 434" question i want to use a Milodon diamond scraper pt# mil-32250. Milodon tells me that the stud kits listed at the mail order houses pt# 81150 will not work with this scraper because of the taller main caps. ARP does not show a stud kit for this application. Has anyone done this and what studs did you use. Maybe Dart sells a stud kit i haven't talked too them yet.
hink 03-10-2009 05:22 PM
We get have gotten alot of calls about this issue with the SHP blocks and some time in the near future ARP is going to offer a stud kit for windage tray.
Any studs you use in the block should the ones for small jounal block as the Darts take shorter hardware then the OEM blocks.
zipper06 03-10-2009 06:09 PM
Thanks Carl,
Right now i have the OEM bolts that came with the block, and the windage tray was an after thought, because i'm sure it's good for a few HP.
wmeabates 03-11-2009 05:00 AM
Zip,Why not weld some mounts in the pan and bolt the screen to them? Bill.
