598 bbc
i am having my big lock built and was wondering if i decide to put a 100 or 150 shot to it will it survive ok ?.....i have gas ported pistons and non billet main capps mark v bowtie block
Re: 598 bbc
Re: 598 bbc
I have a 69'Camaro with a bone stock 350,crank,rods,pistons,heads,intake and carb. except for a mild cam(under .500 lift) and I put on a NOS cheater system with a 100hp shot and it just loves it. I've used a couple bottles already and the plugs look just fine.
Once you start push'in that button it gets real addictive real fast :D Go have fun,man 8) |
"Once you start push'in that button it gets real addictive real fast"
Man you've got the right, this stuff is very very addictive stay away unless you want to spend thousands! lol Seriously I would not be afraid to put a 100 shot on my wore out 1995 suburban and it has well over 240K! Let the madness begin. Goodluck and hangon! Cp |
Start out with a 100 shot, get it tuned in, check your plugs and press that button, Once you get a feel for the tune and adrenelen rush put in a bigger shot.
I think you will find a 150 to 175 shot will be more than suffecient to have a little fun and still be safe level of no2 to prevent destroying your engine. You may want to stay in the 100 to 125 range if your converter isn't set up for nitrous. Too big a shot will baloon the converter. |
| All times are GMT -8. The time now is 01:32 AM. |
