-   -   ran into another problem (https://www.racingjunk.com/forums/showthread.php?t=23489)
bowhay 03-16-2009 08:12 PM
ok so now my truck is makin another wierd knock
but it almost sounds like the trans
it will not do it in park or neutral no matter how high it gets revved
and it only knocks when im slowing down wether it be coasting or braking
and it stops once the trans dropps to first
i looked at the trans fluid level to see and it was low so i added a half a quart of trans fluid cus it was all i had, it was till about a quart low at this point
it has a leak from the dipstick as well
please help out
radicalz 03-16-2009 08:18 PM
bowhay....top it off and see if the noise goes away...could be a flywheel or it could be the front pump in the trans....sounds like it might be the pump....but wont know until it is topped off.
cepx111 03-16-2009 11:36 PM
Check your torque convertor bolts.
Tod74 03-17-2009 08:51 AM
yup...it will sound like the mains are hammering if they are loose.
But you could have hurt the bearings with that deal you went through before.
bowhay 03-17-2009 09:27 AM
idk
i checked the bearings when the motor was out and thats not it
itsabird 03-17-2009 09:50 AM
bowhay this may sound crazy, but you may want to check the alternator, i had a bearing go bad in one, it sounded like all the bad stuff... wrist pin bearings etc, just something to check, good luck.
bowhay 03-17-2009 11:10 AM
how exactly would u go about checking the alternator for that
itsabird 03-17-2009 11:37 AM
take the belt off, or use a ( hose-a-scope) a peice garden hose from the ear aimed toward the alternator, i did both, only in reverse. :)
curtisreed 03-17-2009 12:17 PM
You can also use a long wooden handled screw driver with the metal end on the part in question and put your ear on the handle end. Works great.
I like the hose-a-scope deal. :D :D
Curtis
sm44 03-17-2009 12:21 PM
i had a flywheel cracked that did the same thing.....almost pulled the motor but checked that first.
