RPM activated switch
I installed a RPM activated switch on my dragster, since I have a electric shifter with a spring loaded solenoid. But after I installed the switch my tach quit working. If I disconnect the power wire from my RPM switch my tach works. Has anyone run into this or do I have a bad switch.
Sounds like a switch problem, we just put a msd 8956 in the Biscyne to control the newly installed 200HP nitrous, and it didn't change/anything else electically. Do you have all the wiring diagrams for MSD? There is a download availably at their site for every wiring diagam, in a PDF format. I couldn't install a push bottom on their systems without that download :oops:
Zip. |
I used to have a book that had every wiring diagram in it but it got ruined...only cost 5 bucks.
I went to the MSD site and the instructions they have are the same as came with the activated switch. I guess I'll just have to call them Monday and talk to a tech.
| All times are GMT -8. The time now is 02:02 AM. |
