355 sbc
I have a 671 blower what would i have to do to make this blower work properly on this motor.
depends on if you are going to overdrive or underdrive the pulleys. first thing you need to do is put lower compression pistons in the motor. if the motor isnt built to handle a blower you better start from the ground up...
:shock: Just send me a couple of grand and me and you will be much happier :D
Really , you need to be more specific,,is it a gm blower that needs converting???street???strip???alcohol???gas???indu ction??? if it needs converting the best thing to do is send it to a blower shop and tell them your intentions and most of them will tell you what you need..good luck and let me know and I will send you my address so you can send the money :lol: :lol: |
Go to www.blowerdriveservice.com they have alot of info on there web site. Helped me alot. Good luck
blower, intake, dirve,two carbs, a couple of hours and we will see how long it lasts.
| All times are GMT -8. The time now is 07:08 PM. |
