Calculating Compression
How can a compression reatio be calculated for a blown engine with 10lbs of boost and a starting ratio of 8.5 to 1.
Give specs on engine. Bore, stroke, rod length, & cam specs. mainly valve timing.
TS1955 |
Re: Calculating Compression
Zip. http://www.wallaceracing.com/dynamic-cr.php |
| All times are GMT -8. The time now is 12:57 PM. |
