-   -   rim screws on slicks (https://www.racingjunk.com/forums/showthread.php?t=23658)
camarotale 03-31-2009 01:06 PM
been using the same wheels on a few different sets of slicks and my self tapping holes in the wheels are getting to big and cant get my screws in and dont want to go with a new hole beside the wore out hole any one have a fix.
radicalz 04-12-2009 11:18 PM
Re: rim screws on slicks
are the wheels steel, crome plated, aluminum?....if they aluminum find a competent welder in your area and just have the wheel's hole welded up and redrill them....same for the steel wheels...alot of guys go without even using the wheel screwws...i like them just a little insurance on the wheel spinning in the rim.
Tod74 04-13-2009 03:37 PM
I'd just put new screws in the old holes. they will thread into the tire.. just my opinion
chevyfireball 05-14-2009 02:14 AM
I just drilled new holes next to the old ones. You need the thread in the rim to hold the screws straight as the tire tries to spin on the rim. Without the thread the tires will spin and twist the screws sideways. I wouldn't run without screws even on a 9 or 10 second car. My camaro used to spin the tires on the rims bad.
hammertime 05-14-2009 06:23 AM
how heavy of a car ?
no rim screws for me .. been 7.4's
chevyfireball 05-15-2009 04:06 AM
My Camaro was 3600 lb originaly and it was spinning the tire on the rim up to 8 inches before putting in rim screws...Hell it might've been making full rotations first. Paint a white mark on the back of the tire and rim... you might be surprised.
I think its a safety thing too. If you get a flat it will help keep it from flying off the rim.
