bbc balance question
i have a internally balanced 468 chevy,am getting a dart block and going 4.5 bore,old pistons weighed 587 new ones weigh 618, should i rebalance?
Its pretty close but......I would,.. its all apart,....
Re: bbc balance question
Now your crank is under balanced which is not a good thing over balance that much would be fine 31 GRAMS under balanced is a lot!!!!!!!!!
Yep, definitely balance that thang
Which weighs more 25 lbs of wet sand or 25 lbs of dry sand.
They weight the same, Your new pistons don't. I would most definately get the rotator balanced. |
| All times are GMT -8. The time now is 08:38 PM. |
