bad breaks?
i got a nova with bad breaks. the pedal never gets hard. the master is under the floor it has 2 blue values on it from wilwood 4 wheel disks any thoughts?
Assuming this is a new set up I would bleed the master cylinder first and then the lines again. If it is not a new set up you could have a bad master cylinder or even if it is a new one that has sit for a long time it could be bypassing the fluid. I am no expert but hope this helps.
i dead headed the master and it was fine. the pedal feels like a clulth pedal the fluid looks like coke very brown and it feels like there is sand in it
| All times are GMT -8. The time now is 07:36 AM. |
