turbo 350
i have a turbo 350 in a bracket car. it works great all gears work no problem. BUT IT LEAKS FLUID OUT OF VENT ON TOP OF CASE WHEN CAR IS PUT IN REVERSE. CHECKED FLUID LEVEL IT IS NOT TO HIGH HAVE EXTERNAL TRANS COOLER ON IT AS WELL. NEVER RAN ACROSS BEFORE
JUST WONDERING WHAT COULD BE CAUSING IT. DIDN'T SEE A CRACK IN CASE WHEN PUTTING IT TOGETHER. ANY HELP OR ADVICE WOULD LIKE TO FIX WITHOUT OULLING IT OUT IF POSSIBLE |
tranny
You can put the pump gasket on backwards and that is what happens when you do that.It will fit eather way. Hope this helps.. Kenny
| All times are GMT -8. The time now is 03:06 AM. |
