-   -   Dumb Question- (https://www.racingjunk.com/forums/showthread.php?t=23777)
Scooterz 04-10-2009 04:02 PM
Dumb Question-
I have a TH350 on BBC. It is manual valve body w/ stall & shift kit. All is well... works fine.
My question: It has a modulator on the trans, but NO vac. hose on the modulator... where there is a hose connection on the modulator it is bare (you can see the adj screw) but it is not plugged. Why??? Do I need it? Why is it there if it is not hooked up? etc... Thanks/all. Scooter
BEAST477 04-10-2009 05:02 PM
Hey Scooter, since you have a manual valve body and you shift it manually you don't need a vacuum supply to the modulator. Hope that helps.
fla1976 04-10-2009 05:03 PM
Modulator
I think it is probably there just to keep the tranny fluid on the inside. Don't need it with a manual valve body.
kicker91laser 04-11-2009 03:29 AM
Does anyone make a modulator block-off to eliminate it?
bbchevy 04-11-2009 06:31 AM
Plug
Yes,All of your Trans Parts Manufactures make an Alu.Plug that Goes in Place of the Modulator!
later
G 8)
Scooterz 05-11-2009 01:10 PM
I forgot I made this post... thanks for everyone who replied. Scooter
