-   -   vacum pump help (https://www.racingjunk.com/forums/showthread.php?t=23789)
blownbbc 04-11-2009 06:10 AM
vacum pump help
on alky should i run vacum pump to both valve covers to keep moisture down,,,thanks
ashbros 04-11-2009 02:20 PM
I have ran it both ways on alky, The main thing I try to watch is the amount of vacuum I am pulling I try ti keep it between 4-6 lbs
When I do run a single line I always run it on the opposite side of the vacuum pump. Don't know why, I just always have done it that way. Anyone have any additional comments on that?
hammertime 04-12-2009 06:19 AM
You can do it and wont hurt anything but no need if you have a tight sealed motor its going to pull plenty from one side. I pull more vacuum them mentioned above I want 6-8 at idle.
