Gas or Alcohol
Wanting to buy a dragster to run Quick Rod. I have always ran gas, but was wanting to know what is the advantages or disadvantages of running alcohol? I will also be using a throttle stop. Is one more consistant then the other? I know alcohol runs cooler, is that a problem in a dragster and not being able to warm it up? Thanks
I am a fan of alky but it depends on a couple of things. What size motor. Is the motor going to respond better to gas or alky. I think you had mentioned in another topic 565. I would go alky with a Rupert carb and put one of Sunset Racecrafts throttle stops underneath of it.
Gas or Alcohol
Iused to build my own engines, but now there are so many goog engine builders that build motors pretty cheap. The motor will be 565 or bigger. I was thinking I would maybe run Top Dragster every now and then. I have heard of the Rupert carbs before as being one of the best. Is the Sunset Racecrafts throttle stop a dual butterfly type?
not to mention that alcohol is around 1/4 the price of racing gas :D
Originally Posted by shawnp
that thing is bad to the bone ! I am a alky fan and APD makes a great throttle stop carb to go along with that throttle stop, Sunset sells APDs also. Way to many upsides to the alky for me, cooler, faster as consistent and no more work at all. |
Thanks for all the info. You guys have been alot of help. I guess I will be going with the alcohol. I heard it was alot cheaper, and running cooler, but was,nt sure on the consistacy. I think I will take the advise and order everything thing from Sunset. THANKS AGAIN, you guys are real helpful.
Ask for Tracy Dennis, he owns Sunset. You can tell him Dean Parker sent ya if you want.
| All times are GMT -8. The time now is 10:50 AM. |
