-   -   Switching from Comp to Morel lifters (https://www.racingjunk.com/forums/showthread.php?t=23812)
lanham 04-12-2009 07:57 AM
When switching from Comp Cams 819-16 standard height roller lifters to the Morel Ultra Pro .300 tall lifters part number from PBM RL982 will the pushrods be the same or will i need a different length pushrod? Thanks
zipper06 04-12-2009 12:47 PM
Shorter pushrods required and if you're running shaft rocker setup, you really need to measure for the correct length, not saying it isn't a good idea to measure even with convention roller rockers.
hammertime 04-12-2009 04:45 PM
You may need new pushrods but should ALWAYS check to be sure
lanham 04-19-2009 08:16 AM
I made the swap and the pushrods stayed the same.The pushrod seat location in the lifters measured the same between the two.
oldandtired 04-21-2009 05:54 AM
I know yours are .842, but what is the deal about the 1" dia units? They say the exhaust lifter has two sets of needle rollers. Is this a set inside a set? Dave
