-   -   throttle body swap (https://www.racingjunk.com/forums/showthread.php?t=23825)
txhunter69 04-13-2009 08:37 AM
throttle body swap
i just pulled my 454 out and was wondering if a bored out the stock sbc intake manifold and swapped the computers could a run the throttle body off my 454 on my 350 because the cfm difference is huge and idk if that too much fuel and idk if it will drown out my motor
CamBirdRacing 04-13-2009 11:19 AM
From what I believe, the injectors run different. I'm not a efi expert, but I have tried a v-8 throtle body on a v-6 and it didn't work. Had to swap the injectors over. Other than that it worked.
txhunter69 04-13-2009 11:25 AM
ok well will the injectors give the amount of fuel necessarty cause the 454 tb is huge conpared to the 350 tb
