-   -   cost of balance? (https://www.racingjunk.com/forums/showthread.php?t=23830)
taps 04-13-2009 02:06 PM
cost of balance?
ABOUT HOW MUCH DOES IT COST TO BALANCE A BBC,MAY NEED HEAVY METAL.NEW PISTONS ARE ABOUT 31 GRAMS HEAVIER THAN OLD ONES.
ARUSSELL 04-13-2009 03:35 PM
You should be able to get it done 4 less then 200
ashbros 04-13-2009 03:46 PM
150 to 300 bucks max
radicalz 04-13-2009 04:09 PM
200/300.00...get the balance done it will save future prob's from coming up
BEAST477 04-13-2009 05:06 PM
Yep my last one was $200.
zipper06 04-13-2009 05:58 PM
If heavy metal is involved it can get more expensive but i would think $300.00 max even with heavy metal.
CamBirdRacing 04-14-2009 03:15 AM
My wife bought a rotating assy from OHIO Crank for her car and they did it for $150, and that was internally balanced.
zipper06 04-14-2009 04:52 AM
The big problem in todays world is that almost no one balances an engine any more, since pistons are within a couple grams and rods are within a couple grams, most of the companys only balance the crank shafts, useing the nominal weights of the rods and pistons, there fore the cheap $100.00/$150.00 balance jobs. A few yrs ago i bought a rotating assy from Shafiroff, and crank and rods came from them and the pistons were drop shipped from JE. Pretty good indication that they only balanced the crank shaft.
performanceengin 04-14-2009 08:46 AM
here at our shop we always match pistons, rods before any balance job. we high speed balance and shoot for less than 1 grm. just makes a difference of right or wrong.
zipper06 04-14-2009 10:01 AM
BB&T in Memphis does the same, and the cost is around $300.00, a couple shops here in La. also balances/matches the piston,rods and then the crank also around $300.00.
