cast cyl heads
i have a pair of cast bbc heads the are stamped hi performance should i have these heads reworked and dun up and use them or should i buy a set of aluminum heads ? i pulled the numbers and from what i found out they are 119cc chamber with rectangle ports .they had roller rockers on them when i got them .from what i can they look to be in good shape .some feed back would be nice ? thanks rick
What are the last 3 casting numbers and what do you want to do with them or your application?
Re: cast cyl heads
cast cyl heads
i want to use them for drag racing
Re: cast cyl heads
Re: cast cyl heads
alcohol injected 505 bb, 990 heads hogged out,763 hp at the wheels, 893hp at the crank....
| All times are GMT -8. The time now is 09:31 AM. |
