-   -   machine shop price?????? (https://www.racingjunk.com/forums/showthread.php?t=23847)
txhunter69 04-14-2009 07:45 AM
is 300 toomuch for gettin a 454 bored 40 over gettin it megnafluxed cam bearings and freeze plugs installed???????
cepx111 04-14-2009 09:38 AM
That's about the going rate.
I paid $400 for my 454 to be done, but it was torque plate honed and I had one sleeve put in too.
Cp
txhunter69 04-14-2009 11:19 AM
alright thatdont includegettin my crank turned or gettin it internaly ballanced though did your?
bowhay 04-14-2009 12:04 PM
just call automotive machine and see what they say
cus they did james motor and they beed blasted it jet cleaned it bored it sleeved it and new bearings and freeze plugs for like 400
txhunter69 04-14-2009 08:06 PM
ya dropped it off with them today payin under 300 to get it beed blected jet washed bored freeze plugs cam barings and my crank turned
radicalz 04-14-2009 08:11 PM
make sure they tell you how much they took off the crank so you can get the proper bearings
signsbyesa 04-14-2009 08:23 PM
i was lucky to redue the shops signs and bartered for them to; bore,
cam bearings, freeze plugs, deck surface, and installed a 4 bolt splayed
mains for my bbc, balanced crank, and all came out great. :wink:
the machine shop i went to is right in the middle of a corn field,
the owner has raced everything and now is into racingboats and
builds bb blown motors for flying across the water :shock:
txhunter69 04-15-2009 06:55 AM
theyre installing the bearings so i think ill be of on that
