-   -   crank shaft question (https://www.racingjunk.com/forums/showthread.php?t=23850)
rhiasdaddy 04-14-2009 11:19 AM
i have a stock steel crank shaft can i have it machined in to a stroker crank
bowhay 04-14-2009 12:12 PM
no
u have to buy a crank with a bigger stroke
oldandtired 04-14-2009 01:23 PM
Acutually you can off set grind Chevy cranks for a little more stroke.
Take a 355 (+.030 350) off set grind it .090 and use small journal rods and you get 364 cubic inches.
Take a 468 (+.060 454) off set grind it .090 and use small block rod journal and you get 478 cubic inches.
The down side is special pin placement (compression height) but when we were running class (weight / cubic inches) it was a small advantage that was legal.
bjuice 04-14-2009 05:39 PM
WOW !..Weight vs CI.....now thats one you haven't heard of in a while.
to me that was real racing.....and 468ci was considered HUGE MOTORS. :D
JUST HOW OLD ARE YOU "OLDANDTIRED"?
oldandtired 04-15-2009 05:54 AM
PM sent
russ67chevelle 04-23-2009 07:43 PM
with stroker cranks being able to be purchased for as little as a few hundred or so why??? just me maybe
