-   -   where do i install the high speed bypass (https://www.racingjunk.com/forums/showthread.php?t=23875)
jrthone 04-16-2009 01:19 AM
where do i intall a high speed bypass into my block style metering valve birdcatcher. could someone show me photos or have a really good explanation???
THanks
TS1955 04-16-2009 04:21 AM
On a birdcatcher style injection there is a fuel line that goes from your barrel valve to the distribution block. The by-pass goes in that fuel line just off of the barrel valve. Hope this helps.
TS1955
dak697 04-16-2009 08:01 AM
Here is the link to a drawing I have used. As stated above it can go between the meter valve and the distribution block in the drawing
hope this helps
http://goodvibesracing.com/Technical...ions_BG-TR.pdf
