-   -   Need a better starter for a 383 SBC (https://www.racingjunk.com/forums/showthread.php?t=23904)
lmccoll 04-17-2009 05:01 PM
I have a 383 SBC chevy with 12.5:1 compression. Occasionally, not often, I forget to turn off ignition before cranking and sometimes the motor kicks back. I am on my 2nd "life time warranty" starter from the parts store.
Will the gear drive starters last better? Is a big block starter the same or are they better? Anyway, I would like to get a starter that would take a bit more abuse.
Any help is appreciated.
bryanm 04-20-2009 01:40 PM
A gear reduction starter will work much better. Depending on how much advance you are running, it might be worth installing a starter saver that kicks the timing back 20 degrees while you are cranking it.
fla1976 04-20-2009 01:48 PM
Starter
Here is a cheap fix for the Chevy starter blues. The starter is fine usually, but the solenoid gets hot and can't get enough amperage to crank the engine fast enough.
http://www.oldengine.org/unfaq/solenoid.htm
http://www.streetrodstuff.com/Articl...tart_Problems/
http://www.maliburacing.com/starter_solenoid.html
