head porting
how much will i gain by having my heads ported?i'm running 11.8 comp pistons/736 lift cam[roller]8-71 alky blower/enderle hat modified with square butterflies by gerardot/brodix 2-plus heads/540bbc;;is it really worth the extra money?around $1000 to $1400 i've been told.
Just turn the blower faster , a $100.00 pulley is cheaper
I wouldn't port them, if any porting is done, do it on the exhaust side and make sure you have some big headers(prefferably) zoomies min. 2 1/4" to 2 3/8", you can't put it in unless you can get it out. I run 2 1/4" zoomies on a sm/blk, with track 1 heads.
JMO Zip. |
JMO Zip. |
Whats the problem?
Originally Posted by kwkracing
Whats the problem?
I would port the heads HP is made in your heads, eventhough your cheating running a blower. lol.
JMO Zip. Zip. |
How about getting a really good valve job and bowl port, .. ??
is the valve job the stock VJ from brodix or did you have someone do a tricked out VJ ??? The thing about good heads with blowers, .. no different then N/A, the better the head, the more power AT LESS BOOST, . BUT, .. on a limited budget I gotta agree with Zip, .. fix up the blower and get your pump, .. if there's something left get a good valve job and the valve bowls ported. Curtis |
Whats the problem?
| All times are GMT -8. The time now is 02:36 PM. |
