-   -   650 speed demon help (https://www.racingjunk.com/forums/showthread.php?t=23928)
purplemonte 04-19-2009 07:25 PM
Have a 355 chevy with a edelbrock performer package in it and vortec heads. I put on a 650 speed demon and the car has a bog when you hit the throttle for a second or 2 before it takes off. It is a vacume secondary carb should i go with a stiffer spring to slow down the secondaries.
oldandtired 04-20-2009 12:41 PM
Several possibilties:
Weak secondary spring
Timing
Acc pump linkage out of adjustment
Bad check (the diaphragm thingy) for the main acc pump.
Good luck!!
Jordan1984 04-20-2009 06:48 PM
I had the same problem with my 650 holley carburetor, it was a matter of getting the jets right and the cam pump on the side of the carburetor adjusted right. Finally after many tries I finally got it right.
dparker 04-20-2009 06:55 PM
Re: 650 speed demon help
Nope. Secondaries aren't even opening yet, when your first hitting the throttle. Try a bigger squirter and check for any vacuum leaks.
kbartley 04-21-2009 05:36 AM
650 demon help
I agree w/ dparker. Sounds like a similar situation we were having w/ the monte that I was telling you about. Except the factory distributor was the problem so he bought a new HEI dist. hooked up the vacuum advance and that cured it. Since he drives it everyday this was a good choice for his pocketbook. Kris
kbartley 04-30-2009 05:04 AM
650 demon help
Did you get youre carb straight??? Kris
kbartley 05-22-2009 03:40 AM
650 demon help
I guess he fixed it.
Kris
