-   -   copper headgaskets, sealer? (https://www.racingjunk.com/forums/showthread.php?t=23936)
racecrafter 04-20-2009 07:55 AM
What is your favorite sealer for the water passages when using copper head gaskets?
TS1955 04-20-2009 07:58 AM
Some copper gaskets already have a sealer on them, But for the ones that do not, I use Coppercoat from Permatex.
TS1955
desoto30 04-20-2009 10:46 AM
I used to use GM sealing compound with very good success I don't know if it still is available though
fla1976 04-20-2009 12:46 PM
Gasket sealer
I've had good luck with Hylomar gasket sealer. It was recommended by an area performance engine builder. There are plenty out there. I would use coppercoat if I couldn't find Hylomar.
kwkracing 04-20-2009 06:32 PM
Permatex black silicon
SVRE 04-20-2009 06:47 PM
TS1955
X2
racecrafter 04-21-2009 06:23 AM
thanks guys, I have used all the above with varied sucess except Hylomar ....I remember seeing an add somewhere for a sealer expressly for this but cant remember what or where.....getting old i guess.....
please keep the recomendations comming....maybe seeing the name will jog my memory
Thank you
Robert A.
fla1976 04-21-2009 12:09 PM
Sealant
Here is a website wth some info on Hylomar:
http://www.hylomar-usa.com/?kc=6NbrC...FVCF7Qod5SkOFQ
zipper06 04-21-2009 05:06 PM
Copper coat, spray on.
