-   -   66 chevy 396 (https://www.racingjunk.com/forums/showthread.php?t=23943)
OneFastMalibu 04-20-2009 05:11 PM
66 chevy 396
Casting number is 3855961 I'm just wondering if I can take this 396 and make a decent bracket engine out of it? Anyone on here done this before?
Any help is greatly appreciated.
Thanks in advance
radicalz 04-20-2009 09:55 PM
Re: 66 chevy 396
Thanks in advance
Fast bug you can make a wonderfully consistant engine out of this....I think it a 2 bolt but that is ok....seen 600hp out of these engines...you can put a strker crank...4.25 stroke and make it 461 I think it is with a .030 over bore, put a nice solid cam or roller in it with good heads, Dart Pro 1's 325's or Edlebrock RPM heads....will make easy 600hp with 11:1 compression... :wink:...I had a 402 in a 73 Nova SS that ran 11's with this set up in it...minus the stroker crank...
Tod74 04-20-2009 10:42 PM
.030 over bore with a 4.25 stroke is 454 ci
cepx111 04-20-2009 11:31 PM
I ran a 396 in my old 73 nova for many years, it was a great bracket motor.
Mild (305magnum) hydralic cam, 11 to 1 piston's, team G, 750 Dp, 4.11 gear's - it ran 7.50's in the 1/8 all day long which would equate to high to mid 12's in 1/4. I think?
OneFastMalibu 04-21-2009 12:21 AM
Thanks guys for the reply's This is a complete engine out of a 66 Impala. The wife wants to give a shot at racing so I thought I could build it up and toss it in my 79 Malibu and let her go racing while building a bigger one for the car.
CamBirdRacing 04-21-2009 03:16 AM
I have a set of 67 396 closed chamber heads that will fit. I think they are 215 castings.
zipper06 04-21-2009 05:11 PM
Not a good idea :shock: , that motor is worth a ton of money to #'s matching freaks. You can sell that motor for more that than your 73 is worth and build a much stronger motor with the proceeds :idea: think about it :?:
MEMRACING62 04-21-2009 05:38 PM
DITTO :!: :!:
Tod74 04-21-2009 05:44 PM
I agree....I took a 1970 512 casting 454 block and factory forged crank...used it in a bracket car and broke a roller lifter and cracked it.... And the mess that pumped through it got the crank too . It's still usable but is now .030/.030 :(
