code problems
i ran a dignostics on my truck it a 92 so i had to use the paper clip trick it read out 43 which i think is the throttle poistion sensor so i replaced it and its still reading the same code any ideas??????
you have to clear the computer or it will still show the code
ok so how do i do that
DISCONECT THE BATTERY FOR THIRTY SECONDS AND RECONECT
Assuming this is a chevy truck a code 43 is an EST problem.
ok well the tps replacement actually helped some but what would a do to fix the EST problem
| All times are GMT -8. The time now is 06:52 PM. |
