400 sb ?
i have a 417 ci stroker,i have heard so much about 400 sb good and bad,so was woundering you guys opinion,mine is a eagle roller w/dart pro one heads,,it has a gm block witch i know is the weak point,,,,Steve
Those engines do make good power for a small block sounds like you got a good combo there ya the weak part is the block they usually crack .
| All times are GMT -8. The time now is 11:47 PM. |
