-   -   Tubes in Micky T's ET Drag (https://www.racingjunk.com/forums/showthread.php?t=23987)
Pdmracing 04-23-2009 10:19 AM
New to this game, Summit & mickey T says to run the tubes, but RJ race cars book says no way? what do you do?
thanks
BEAST477 04-23-2009 04:39 PM
I've got tubes in mine. No problems. Running low 9's.
johnracer 05-04-2009 11:40 AM
Tubeless for sure. They'll work better.....but they do leak. I run Goodyears tubeless too.
Johnny
fla1976 05-04-2009 12:26 PM
Tubes
I ran my Hoosiers tubeless and coated the complete inside of the tire with Ivory soap before mounting them. The soap seals the tires without adding weight and never had a problem with the tire leaking down. It's an option.
Tod74 05-04-2009 12:28 PM
I've ran both. Car worked the same either way, but Tubes are pretty heavy.
dparker 05-04-2009 01:29 PM
Tubeless all the way. lod school for me no rubbers.
Tubes seem to push on the center more.
I would say whichever you prefer will be just fine........Works both ways.
chevyfireball 05-14-2009 02:03 AM
Depending on how big your tires are, tubes can effect the way the tires wrinkle on launch. I'd run tubeless if possible.
68bbnova 05-19-2009 07:24 PM
I have some steel rally rims I ran tubes in, but now I want to try tubless. What valve stem would I use, now that the hole was drilled to 1/2" ?
I972Nova 05-20-2009 02:38 AM
You can get valve stems at Jegs or whereever that will work in a .453 or .625 hole. These are what I had to get with the wheels on my truck, the guy I got them from used tubes.
http://www.jegs.com/i/Detroit+Wheels...900-4/10002/-1
68bbnova 05-20-2009 06:03 PM
Thanks, Its been a long time since I bolted in all my valve stems, and could not remember how they sealed.
