What Is Best Fuel Choice C14,C15 or C16 for my application
I have a 565 BBC in a drag race application .
Specs single 1250 hp 14-1 compression 324DR12 cam 2350 LBS CAR 6000 convertor on brake 7500 max RPM If you leave opinion please include why you believe your answer to be the best choice .Thanks |
C-15 is the fastest fuel of the three
C-15 is the best for N/A big bore engines and has only 10% aromatic hydrocarbons. The burn rate is faster than C-16 which works best in blown and turbo applications that require high detonation resistance. Now C-14 has no aromatic hydrocarbons which will make it difficult to read your plugs due to no soot indicators that most of us are used to seeing on the plug. The cost of these fuels are nearly the same and I have used all 3 in big bore N/A single carb engines. The C-15 is much faster in 4.60" bore engines than C-16 by a bunch due to the faster burn rate, and the SG of .713 keeps you from running huge jets that the C-14 will need with it's .690 SG.
C-14 needs to be tuned on the dyno with oxygen sensors to get the tune-up quickly, plug reading is challenging without aromatic's. C-16 has 6 grams of lead compared to 4.23 that the 15 and 14 have and having 20% aromatic hydrocarbons make's the plugs dark when rich. C-15 is clean burning, low in aromatics, high octane and fast burning. My first choice for your application C-15, C-14 would be my second choice. I was once informed that C-15 is C-12 and C-14 mixed 50/50. The behavior of 15 is similar to both 12 and 14. For what that might be worth? Bruce |
Re: C-15 is the fastest fuel of the three
C-14 needs to be tuned on the dyno with oxygen sensors to get the tune-up quickly, plug reading is challenging without aromatic's. C-16 has 6 grams of lead compared to 4.23 that the 15 and 14 have and having 20% aromatic hydrocarbons make's the plugs dark when rich. C-15 is clean burning, low in aromatics, high octane and fast burning. My first choice for your application C-15, C-14 would be my second choice. I was once informed that C-15 is C-12 and C-14 mixed 50/50. The behavior of 15 is similar to both 12 and 14. For what that might be worth? Bruce Q16 will work well in any drag racing application. Q16 is highly oxygenated, requiring a 4-6% increase in fuel flow, which will make 3-5% more power than competitive 116 octane fuels. Q16's oxygenation will significantly expand the range of air/fuel ratio acceptability, so performance will be more consistent and won't vary as dramatically with altitude or density changes. For bracket racers, variations in ET from run to run will be substantially reduced. This added fuel flow also effectively increases its octane by 6-8 numbers above its standard ASTM octane rating. Just a thought............... |
Dparker wrote-
One thing you might look at also would be Q16. Q16 will work well in any drag racing application. Q16 is highly oxygenated, requiring a 4-6% increase in fuel flow, which will make 3-5% more power than competitive 116 octane fuels. Q16's oxygenation will significantly expand the range of air/fuel ratio acceptability, so performance will be more consistent and won't vary as dramatically with altitude or density changes. For bracket racers, variations in ET from run to run will be substantially reduced. This added fuel flow also effectively increases its octane by 6-8 numbers above its standard ASTM octane rating. Just a thought...............[/quote] Hey Dparker, when did you start selling Q16? I hope you negotiated a decent kick back with VP for this commercial. Just kidden buddy. I hated that stuff. Lots of unintended consequences when running that much alcohol in your fuel when you are used to running plane ole gasoline. Very corrosive stuff and $17.00 per gallon. Bruce |
Dparker wrote-
One thing you might look at also would be Q16. Q16 will work well in any drag racing application. Q16 is highly oxygenated, requiring a 4-6% increase in fuel flow, which will make 3-5% more power than competitive 116 octane fuels. Q16's oxygenation will significantly expand the range of air/fuel ratio acceptability, so performance will be more consistent and won't vary as dramatically with altitude or density changes. For bracket racers, variations in ET from run to run will be substantially reduced. This added fuel flow also effectively increases its octane by 6-8 numbers above its standard ASTM octane rating. Just a thought............... Hey Dparker, when did you start selling Q16? I hope you negotiated a decent kick back with VP for this commercial. Just kidden buddy. I hated that stuff. Lots of unintended consequences when running that much alcohol in your fuel when you are used to running plane ole gasoline. Very corrosive stuff and $17.00 per gallon. Bruce You think VP might give some kickback if I forward this thread to them?lol. |
On second thought, VP's advertising division might try to charge you with plagiarism! :shock:
Bruce |
Sorry, when your old like me sometimes its just easier to cut and paste...
I'm sorry Dean, I thought it sounded like an ad that I just read a few issues ago. I do not have a scanner to cut and paste with, but knowing that info after my comment,sure makes my idea to solicit a kick back unrealistic now............ :lol: :lol:
Bruce |
Have you ran this year? How fast did you go?
Would you believe that every single weekend that we have had to test including last weekend was rained out or snow was in play! It is just killing me to go into the first points event this saturday with a new 4 link set up, new cam shaft and 275 more horsepower from 5100 rpm to 7100 with the same peek power and not one test pass yet.
Michigan is not under the global warming spell I can tell you that for sure. Bruce |
| All times are GMT -8. The time now is 11:08 PM. |
