477 BBC HIGH RPM MISFIRE
I have been fighting this for long enough... 477 BBC Dart pro 1 heads, Roller, 13:1, BG 400 pump (new), Quick Fuel 1050 Alch, MSD Distributor ignition.
Between the 1 -2 shift the car started popping slightly, steadily got worse. EGT was reading high. Put larger jet in carb. Kept getting worse as time went bye. Don't race alot so a few weeks go bye between attemts to cure. Thought it was a fuel delivery problem. Ordered new BG 400 pump and 4 port reg. Installed but no cure. Got up to almost 200 jets and still had hot EGT temps. Winter came a I said I'll see you next year. Ordered new valve springs and installed. Went out today and problem still there. Any other things I am missing? I am probably looking over the problem so don't be afraid to mention some silly questions at this point. Thanks in advance. |
What kinda fuel pressure ?
Also when you were putting bigger jets in the carb was the egt going higher or lower ? What fuel ya use ? |
I have 8 to 9 lbs of fuel pressure. When I started changing jets, The EGT did not change or got worse. I am i at 1335 degrees and only running 1/8 mile.
Sorry. I use V/P alch.
Which VP fuel the normal m1 or m5 ? |
Yes float levels been checked. I guess M1 on the fuel.
increase the fuel pressure some and see what happens, could be a bad gauge and be lower then actual ?
Did that. Put a second gauge on it and it is set now just before it runs past seat.
what high side chip does it have in it ?
Set to 7600. But now I can't even get to the shift point to make it shift it pops so bad. Shift point is at 6500.
| All times are GMT -8. The time now is 08:42 PM. |
