-   -   BBC tuning question? (https://www.racingjunk.com/forums/showthread.php?t=24034)
whitey70ss 04-27-2009 03:32 PM
A friend of mine has a bbc in a jet boat the engine idles fine but as soon as you bring it of idle it starts popping through the exhaust. I tried moving the distributer to the left and it got worse so I tried to the right = worse. I'm wondering if its in the carb its a marine style holley p/n R84018-2 Any suggestions would be helpfull. Thanks
fatjodycat 04-27-2009 03:48 PM
im thinking rounded lobe on cam.
TS1955 04-27-2009 06:45 PM
Broken or weak valve spring(s).
TS1955
russ67chevelle 04-27-2009 09:38 PM
running lean???
Tod74 04-27-2009 10:43 PM
Re: BBC tuning question?
why not put a light on it...time it correctly and stop moving it? That would eliminate that variable. Not being a smart alek just a suggestion.
cepx111 04-27-2009 10:46 PM
I'd pull the valve covers and do a looky loo.
He's probably got a broken valve spring, broken rocker arm or pushrod not on the rocker arm, been there done that, I hate that sound.
oldandtired 04-28-2009 02:48 AM
x2
I've seen it too many times on BBC marine engines. Dave
whitey70ss 04-28-2009 02:57 PM
took the valve covers off found a broken spring . I appreciate the help. sorry I'm such a amature :oops:
BEAST477 04-28-2009 03:40 PM
Don't be sorry. Everybody has to start somewhere. The easiest way to learn is ask ???
