-   -   Nosing over (https://www.racingjunk.com/forums/showthread.php?t=24043)
I972Nova 04-28-2009 03:09 AM
Nosing over
Hey I snuck the cars out this weekend. The truck ran pretty good, it went 11.22 @ 118. Not bad for a cheapy motor.
BUT
The dragster was nosing over at about 800 feet and ran 8.96 at only 138 mph. On the first pass fuel psi dropped to 5.5 under load, so I turned it up and it stayed above 6.5 but still did the same thing. I am thinking the problem is in my fuel delivery. I have a Mallory comp 250 fuel pump, but I only have about a foot of -8 braid feeding it. It makes a 180 degree bend.
Does anybody else think that this could be the problem?
I was looking at putting -12 with 90 degree ends on them to be less restrictive and give it more volume.
It noses over after about 6 seconds of full throttle, but is not related to RPM. I shift at 6800 and it noses over at about 6400 on the big end.
What do you guys think? Thanks
itsabird 04-28-2009 06:13 AM
what track were you at josh? 15-20 mph wind sat. bad head wind at the track i went to.
curtisreed 04-28-2009 06:58 AM
Josh,
Is your car on gas or alcohol?
Curtis
dparker 04-28-2009 07:19 AM
After setting all winter you might check your needle seats. Sounds like it might have some sh#t keeping it from opening and closing like it should.
hammertime 04-28-2009 07:32 AM
x2
Also 180 degree bend isnt a good thing, use -8 and a 90 degree
I972Nova 04-28-2009 01:16 PM
Its on gas. I was at trails. There was a head wind, but the car completely laid over like you went from full throttle to half throttle. The car is crisp and very driveable it just flatlined after the 1/8th. It went 5.595, 5.597 and 5.601 in the 1/8th.
I'll try to get a picture of my feed line either tonight or tomorrow...
Thanks Guys
dparker 04-28-2009 02:23 PM
Thanks Guys
Heck I'd leave it there as close as those numbers are.......... lol
I972Nova 04-28-2009 03:54 PM
I agree Parker, but the problem is I was running 1/4 mile and went 9.02, 9.06 and 8.96 at speeds of 138, 135 and 139. It would have been hard to beat on the 1/8th though. I was real happy with the truck though, it ran 7.142, 7.143, 7.146 and 7.147. I lost with a .014 package in Pro. I cant wait to go to the 1/8 mile track...lol...
dparker 04-28-2009 08:46 PM
Our SBC dragster did the same thing at the first race this year. I noticed that three of the four high speed air bleeds had green muck in them. I pulled the metering plates and sprayed carb cleaner in the holes and then blew them out. Worked great afterward. Some of the problems with the 113 and other oxygenated fuels. I also noticed that the needle seats where sticking a little also.
