Gauge pack.....what do you find most useful?
My car came with what I believe to be the minimum set of gauges.....Tach, Water, Oil Pressure. I'm adding an outside fuel pressure gauge. And since I've got a PG tranny and a high stall converter....sure would be nice to keep an eye on the tranny temp.....then that lead me to oil temp as well.
So I may be getting to info overload....so I thought I would check with you guys and see what most find necessary vs. just nice to have. Thanks! |
haveing good info is alway's nice, water temp, oil, tach, are prob.. the most used, but if you have the beaver pelt's go for the rest.
| All times are GMT -8. The time now is 02:11 PM. |
