ENGINE OIL PRESSURE
ANYBODY GIVE ME ANY HINTS ON WHY I'M DROPPING ABOUT 30 LBS OF OIL PRESSURE AT 5200 RPMS IN A DRAG BOAT WITH BRAND NEW 454. COULD IT BE RUNNING OUT OF OIL AT THE PUMP OR IS IT SOMETHING MAJOR ANYBODY?
I hope you're not using a Fram oil filter.
no fram
nope using a wix racing filter
Just a thought...Does this engine have a "stock" oil pan & a high volume pump? I've seen this happen before. A high volume pump can suck a 4 qt pan dry. Just something to look in to. JMO
TS1955 |
i have a high volume in a stock pan and it works fine
but its a 5 quart, it also holds closer to 6 though at the ful mark what size is ur pan |
Re: ENGINE OIL PRESSURE
| All times are GMT -8. The time now is 10:02 AM. |
