-   -   Stock powerglide case (https://www.racingjunk.com/forums/showthread.php?t=24063)
coloradoracerguy 04-28-2009 07:11 PM
What can a stock powerglide case hold up to in regards to hp limits? How much does an aftermarket bellhousing (i.e. an Ultrabell) improve upon that, if any?
Thanks
Mark
hammertime 04-29-2009 06:41 PM
Re: Stock powerglide case
Thanks
Mark
Mark it really depends on the weight of the car and the hp, a light car (dragster) you can run a stock case with 1000-1100 and be plenty fine, a 3300lb door car with less hp wouldnt hold up.
IMO if your going to spend the money buy the entire case, it'll be worth it in the end.
us7race 05-02-2009 11:18 PM
I know a dragster with a stock case glide running 4.50's in the 1/8th. it does have the ultrabell.
chevyfireball 05-07-2009 02:24 AM
I wouldn't be too concerned about the case. You need to make sure the guts and convertor are built to handle it. You can always put a blanket on the case and sheild the bellhousing.
Tod74 05-07-2009 03:28 PM
I have a stock powerglide case behind a 540 in a 3200 lb car...Stock planets and all. It has a COAN shaft and transbrake in it along with a good servo thingamajigger but the rest is factory junk....knock on wood no trouble so far.
TS1955 05-07-2009 04:18 PM
I agree with chevyfireball. Have a good planetary, input shaft, convertor etc. Stock cases are pretty strong.
TS1955
coloradoracerguy 05-07-2009 06:40 PM
Thanks for the input guys!
Mark
ken0069 05-13-2009 03:38 PM
I ran a stock case with a TCI planetary and guts in a 3500 lb door car with a 600+ HP SBC engine for the better part of 9 years and never hurt a case.
Had two dragsters, one 482 BBC and one 434 SBC with stock cases that worked fine.
I've built a s**t load of'em, including one behind a 496 BBC in a door car that have had zero case problems also. Ya have to realize that the load on the gearset is internal and there is very little radial jor axial force involved.
If that's what you got, then run it!
