horses???
the big block im building will be pretty weak but im wanting to get and estimate of hp
468 keith black hypurtectic flat tops stock rods and crank edlebrock airgap intake heads ported and milled down 4 and get a good valve job done on them get the cam specs on next post |
Brand: Isky Racing Cams
Product Line: Isky Hydraulic Roller Tappet Camshafts Part Type: Camshafts Part Number: ISK-396284-294 Cam Style: Hydraulic roller tappet Basic Operating RPM Range: 3,000-7,000 Intake Duration at 050 inch Lift: 238 Exhaust Duration at 050 inch Lift: 248 Duration at 050 inch Lift: 238 int./248 exh. Advertised Intake Duration: 284 Advertised Exhaust Duration: 294 Advertised Duration: 284 int./294 exh. Intake Valve Lift with Factory Rocker Arm Ratio: 0.578 in. Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.608 in. Valve Lift with Factory Rocker Arm Ratio: 0.578 int./0.608 exh. lift Lobe Separation (degrees): 110 Intake Valve Lash: 0.000 in. Exhaust Valve Lash: 0.000 in. Computer-Controlled Compatible: No Grind Number: RR-284/294 Quantity: Sold individually. Camshaft, Hydraulic Roller Tappet, Advertised Duration 284/294, Lift .578/.608, Chevy, Big Block, Each with isky anti-pump-up lifters |
Put a 871 supercharger on it with about 5-6 lbs of boost it will be around 550 to 600 Hp. as it sets my guess is 375- 400 hp depending on carburation.
alright i knew it wouldn;t push out much cause i aint puttin much in it but im thinkin proly a 750 or 850 demon carb
| All times are GMT -8. The time now is 04:29 AM. |
