-   -   honda (https://www.racingjunk.com/forums/showthread.php?t=24206)
duckhunter 05-11-2009 01:08 PM
honda
i have a Honda prelude i run in a 4cylinder class it has a 1.8 dule carb moter how do i get rid of the hi rpm miss
Tod74 05-11-2009 01:12 PM
Re: honda
Find out what is causing it and repair it. That should get rid of it.
JK
Welcome to the board...I don't know anything about HONDAS but even so you will need to provide more info on the entire combination...too many things can cause a miss. Could be fuel or ignition.....valve springs...many things.
TopspeedLowet 05-11-2009 01:14 PM
I was thinking the stereo may need a new amp with a set of 16" speakers in the rear. 8)
MEMRACING62 05-11-2009 01:23 PM
replace exaust tip with a chrome one, that should fix it :idea: :idea: :P
TS1955 05-11-2009 01:26 PM
You guys are too funny!
TS1955
fla1976 05-11-2009 01:49 PM
Honda
What RPM are you talking about? At the end of the run or at the shift point in every gear? What fuel pressure are you showing? Stock ignition? After market cam and springs? Stock valve train? Header? Type of fuel? There are a lot of possible causes and a lot more info needed.
Tod74 05-11-2009 04:34 PM
Fart Can
MEMRACING62 05-11-2009 05:27 PM
x2, :lol: :lol: :lol:
bbchevy 05-11-2009 05:47 PM
Miss?
I Got this1 Guys!
I seen this in a earlier Post!!
NGK or Nippondenso SparkPlugs,He said thats why the Imports run so G@@D,and get such GREAT MPG!!!!
Later
G 8)
FullTimeRacing 05-11-2009 05:51 PM
See that,Y'all scared another one away. :lol: :lol: :lol: :lol: :lol: :roll: :roll: :roll: :roll: :roll: :roll:
