-   -   Motor mounts (https://www.racingjunk.com/forums/showthread.php?t=24233)
kod99 05-13-2009 03:58 PM
Motor mounts
I was wondering what you guys with dragsters use to attach your motor mount plates to the frame rail? Mine are attached with srew clamps. Are they strong enough or should I chage them out to something else?
Thanks
TheYellaBrick 05-13-2009 04:06 PM
:shock: :shock: :shock: :shock: do you mean HOSE Clamps ? :shock: :shock: :shock:
mopar1968 05-13-2009 05:19 PM
I hope not Double-D the engine will pass the rail :lol: :lol: :lol:
''JUST MY TWO CENT'S WORTH''
http://www.racingjunk.com/profile/163312
fla1976 05-13-2009 05:22 PM
Mounts
Sure hope you don't mean hose clamps! Are you using actual mounts or a motor plate. If you are using mounts , I'd go to plates. I would weld the brackets for the plates.
THERATTLER 05-13-2009 05:26 PM
MY MID PLATE IS BOLTED TO TABS THAT ARE WELDED TO THE FRAME , THE FRONT MOTOR PLATES ARE BOLTED TO SADDLES THAT SIT ON TOP OF FRAME WITH BAND CLAMPS AROUND THEM , NOT WORM DRIVE HOSE CLAMPS...THEN I HAVE ENGINE LIMITERS THAT BOLT TO TABS ON THE FRAME AND THE MOTOR MOUNT HOLES IN BLOCK TO STOP BACK AND FORTH MOVEMENT...
Tod74 05-13-2009 05:32 PM
These pics are from HAMMERTIME'S Page....http://www.friendpages.com/albums/99/3375999.24577.jpg
http://www.friendpages.com/albums/10/3375610.11566.jpg
THERATTLER 05-13-2009 05:39 PM
THATS THE WAY MINE ARE....EVERY DRAGSTER I HAVE EVER SEEN IS THIS WAY IN ONE FORM OR ANOTHER..ONLY THE MID PLATE IS ACTUALLY BOLTED TO FRAME..I HAVE A BAND CLAMP ON FRONT PLATE SADDLE , NOT HOSE CLAMPS..THERE IS A BIG DIFFERENCE...
mopar1968 05-13-2009 05:44 PM
Hey Double D i understand the clamp thing now, must be a ''CHEBBY'' don't have enough power to break them :!: :!: :lol: :lol: :lol:
suicidebomb 05-13-2009 05:55 PM
Maniac is spot on, and the clamps are called t-bar clamps. Funny car engines are put in the car this very way, they hold the engines in them...Well, most of the time.
kod99 05-13-2009 06:10 PM
Thanks guys.
My mid-plate is bolted to the frame rails but I will change the front worm type clamps to 'T-bar' clamps. The worm type clamps didn't look strong enough. That's why I asked you experts!
