-   -   1.98 gear set (https://www.racingjunk.com/forums/showthread.php?t=24238)
2644 05-14-2009 05:39 AM
1.98 gear set
Looking at buying a glide which suppose to have a 1.98 gear set in it, would this be a straight cut, anyway of knowing without going into it? Anyone running one, are they as good as the 1.80s, reliable? was told the set cost $700 new. Thanks
ML3885 05-14-2009 06:59 PM
1.98
had a 1.98 gear set in my car when we got it, was not straight cut gears and was set in a 1.82 carrier, didnt last long.was stamped 1.98 on the end of the output shaft, hope this helps a little.
dparker 05-15-2009 07:30 AM
If it cost just $700.00 I would say its probably set up on a 1.82 carrier if so it won't handle much HP. Only way to check for sure is to pull the pump, loosen the band and slide the plants out, not to hard. The only thing you'll have to readjust is the band.
2644 05-15-2009 03:31 PM
Thanks guys, sounds like I may need to stay away from this one.
cepx111 05-15-2009 10:55 PM
Go with 1.76 planetaries.
wheelsup330 06-21-2009 05:16 PM
learning event
I just toasted my TCI 1.96 planets in my glide. They had about 50 passes in my 8 sec SBC Vega, they were in a hardened 1.76 style carrier with a 4340 output. The carrier is even questionable, I will have to magnaflux it to tell for sure if its ok.
My point is this: The lower the gear set (more reduction) the LESS tooth contact area there is to support the power.... just like a ring and pinion set. So be careful how low you go. if you really need the low gears get a 3 speed tranny.....
