-   -   MSD & a two step (https://www.racingjunk.com/forums/showthread.php?t=24246)
TS1955 05-14-2009 02:03 PM
MSD & a two step
Just curious on how many racers use a two step for a launch control & how many use it as a safety device, putting in a chip that's a little above your convertor stall?...I personally use it as a saftey device. What do you do?
TS1955
hammertime 05-14-2009 04:14 PM
launch control, more consistent this way for sure.
curtisreed 05-14-2009 05:44 PM
I use a three step, burnout, starting line, and high side.
Curtis
kod99 05-14-2009 07:04 PM
Curtis
X 2
TS1955 05-15-2009 02:15 AM
I've never had a problem with being consistant, 60ft times don't vary much. Except when I used to Super Gas race with a Chevy Monza with a 12 bolt rear and I chucked a rearend on the starting line...60 ft sucked on that pass. Now they vary from track to track a little. I feel a 2 or 3 step is hard on the engine. JMO
TS1955
Tod74 05-15-2009 03:57 AM
Re: MSD & a two step
TS1955
what are you safeguarding against??? don't say over revving please....I mean you have the high end limiter to keep the motor together what is the purpose of limiting just past the converter?
hammertime 05-15-2009 04:02 AM
TS1955
how consistent is it ?
fluid temps changes, fluid gets thinner when it gets hot and the stall changes, meaning it could go from (example) 1.20 to 1.21-1.215
TS1955 05-15-2009 05:57 AM
I'll answer Tods question first. As long as you have your tranny brake activated and you are on the "low" side of the two step, the high side chip doesn't function. So if by chance you come up on the converter and it breaks, you have NO safe guard. Unless you have a chip in the low side.
When I used to Super Gas race I would leave the line at what ever the converter would stall at for reaction time. I got used to it and haven't changed. Hope this helps.
And hammertime my 60 ft will vary about .01-.015 about the same as yours.
TS1955
hammertime 05-15-2009 07:27 PM
TS1955
That was an example above, you should start using a 2 step and tighten them up. mine last time out went from 1.128-1.130 it moves much more then this its time for tires or something else on my car. :D
Tod74 05-16-2009 01:42 AM
TS1955
I get it....seems obvious now that you explained it. I didn't think about the high side being shut off while the button was in....duh. :D
