Oil pan change: SBC in 70 Chevelle
Question: Is there an EASY way to change out the oil pan in a 70 Chevelle with sbc? There doesn't seem to be enough room to clear the front crossmember without loosening the motor mounts and raising the motor itself? Any ideas/suggestions? Thanks. Mep
thats what youre gonna have to do! I went through the same task not long ago.
x2 just go ahead and do it. you'll be done before u know it.
Hope you are putting a good pan on and you might consider changing the oil pump when you do........... |
I'd just pull the motor and be done with it....
YEP!
Yep!!! X3 pulling the motor is actually the easier route. What if you do it the other way & have a leak when you're done. Been there, done that, & It tissed me off!
JMO, Kris |
| All times are GMT -8. The time now is 04:13 AM. |
