-   -   engine pops back thru the exhaust (https://www.racingjunk.com/forums/showthread.php?t=24265)
alleyk 05-16-2009 08:11 AM
460 ford installed new cam lifters and springs(hydraulic) new wiand plugs< what can it be
mopar1968 05-16-2009 08:13 AM
More info, when does it do this, street car, race car :?: :?:
''JUST MY TWO CENT'S WORTH''
http://www.racingjunk.com/profile/163312
alleyk 05-16-2009 08:52 AM
race car, mostly at idle
dparker 05-16-2009 09:38 AM
Valve staying open or closed.....
TS1955 05-16-2009 11:02 AM
Sounds like ya have a valve or two too tight to me! JMO
TS1955
dparker 05-16-2009 11:36 AM
Sometimes it takes a little while for the lifters to pump up. Make sure you recheck the lash after you run the engine a little while. If there pumped up you should have oil coming off all the rockers.
mopar1968 05-16-2009 12:30 PM
Yeah i would have to agree, back the lash off a bit and see what happens :!: :!:
justin45 05-17-2009 07:41 PM
maybe u didnt degree ur cam right????
onedragracer 05-18-2009 03:04 PM
Your popping through the exhaust because the vavle lash is too tight on the exhaust valves or lobes going flat on the camshaft.
