-   -   HP Guess (https://www.racingjunk.com/forums/showthread.php?t=24268)
heshtesh 05-16-2009 03:12 PM
HP Guess
This is the engine i'm running in my 89 1/2 ton two wheel drive this summer i'd like to get some guesses on HP before it hits the dyno next week. The truck is in getting a three link installed along with a 9" ford rear should be done next week.
358ci
Scat 4340 43lbs crank
eagle 6" H beam rods
JE 12.1 to 1 pistons
Reed solid roller 262/267 @50 618/625 lift 106 split
Brodix alum 11x heads fully ported polished,bench flowed should be approx 240cc on intake side i don't have flow sheet yet
jessel ss rocker system 1.5 ratio
Mass flow fuel injection with 45lb injectors
My guess a solid 550HP
Tod74 05-16-2009 04:09 PM
I think you are pretty close...1.5 hp per cube is 537
fla1976 05-16-2009 04:29 PM
HP
I'd guess around 550.
mopar1968 05-16-2009 04:33 PM
I would say a Briggs & stratton has more :!: :!:
''JUST MY TWO CENT'S WORTH''
http://www.racingjunk.com/profile/163312
Tod74 05-16-2009 04:35 PM
MOPAR must have lost to a Chevy recently..... :lol:
mopar1968 05-16-2009 04:54 PM
Nah thier not quick enough, get up to the light's and still have to give at least 2 lights, then feather the throttle so when i pass them it doesn't look so bad on them at the end.
MEMRACING62 05-16-2009 04:59 PM
OH BROTHER ITS GETTING DEEP AROUND HERE, TIME TO PUT ON THE HIP BOOTS :!: :lol: :lol: :lol:
heshtesh 05-17-2009 08:06 AM
Mopar 1968
Just wondering are you going to have to kiss up on Obama to by parts for that Mopar from GOVERNMENT MOTORS?
mopar1968 05-17-2009 08:09 AM
Nope i work at a dealership so i can get all the MOPAR parts i want, check my profile, and the parts doesn't cost me a penny :!: :!: I don't kiss anyone's a$$ for anything :!: :!: Now see that's is what i don't understand about idiots like you, you really don't understand what is going on with the auto industry but you come on here with 3 post under your belt and start calling it goverment motor's, Please the next time you start to shoot off your mouth about something you have no idea about, DON'T :!: :!: And by the way GM is in alot worse shape them chrysler is, chrysler closed 700 dealerships, GM is closing close to 1200 :!: :!: enough said :!: :!:
heshtesh 05-17-2009 09:10 AM
Relax
Mopar1968: I would have thought you had a sense of humor when you posted ( I would say a Briggs & Stratton has more ) as i took it in good humor. When i made my comment it was meant in good humor but you appear to lack the maturity to recognize it for what it was. As for you having 912 post and myself only 3 it only took to reading the third post from you to realize that i won't bother to read another. Go ahead and rant i won't waste my time as i see your opinions as irrellavent.
