-   -   Does anyone on here use Lucas oil treatment (https://www.racingjunk.com/forums/showthread.php?t=24277)
lanham 05-17-2009 09:20 AM
I use Brad Penn 20/50 oil and was wondering about using Lucas oil treatment with it.Does anyone know if the Lucas causes the oil to foam or is it good stuff to use?Thanks
TS1955 05-17-2009 09:28 AM
Lucas additives are very good...I would recommend them. Especially if you run an oil with little or no zinc you add the Lucas "Break-in" additive part #10063. Can also be used in every oil change. Zinc is a necessity for flat tappet cams. JMO
TS1955
cubed 06-04-2009 05:11 PM
lucas oil
if you ever have a power-steering leak their product is great.
rob41willys 06-04-2009 09:51 PM
The Brad Penn oil is already very good.I don't think you need the addative
Scooterz 06-05-2009 10:10 AM
Agreed. Brad Penn has (2) 20/50 oils... one in the racing line (prt# 7119) that is higher in ZDDP (zinc). The other is in the regular line.
The only thing I see any additives accomplishing is alot of agressive marketing. Remeber back in the 90's when people were paying $50.00 for one quart of "Slick 50??" It is all marketing. Use great oil & change it often. Scooter
oldandtired 06-05-2009 10:50 AM
x2 Rigsby.
The aggressive marketing is working. I can't afford a top fuel team, much less sponser a series!!!
Dave
MEMRACING62 06-05-2009 01:28 PM
FRAM OIL FILTERS IS A GREAT EXAMPLE OF MARKETING OF A CRAP PRODUCT. OFFICIAL FILTER OF NHRA , WHAT A JOKE!!
deepockets 06-05-2009 02:57 PM
i use 1/2 bottle to every oil change. since the government regulated the ammount of zink that can be use in the majority of off the shelf oils, i dont think it would be a bad idea to boost the zinc level a little. if people are knocking cam lobs flat from the reduced ammount of zink, it must have gtreat lubricating properties. it might also help the wear of the other engine components
mopar1962 06-28-2009 03:38 AM
OIL
I run a 515 methanol injected chevy.15 to 1 compression and ive gotten tired of $100 PLUS OIL CHANGES. i NOW RUN 20 50 vr1 VALVOLINE RACING OIL AT $389 A QUART LAST 2 YEARS AND HAVNT HAD A DAM PROBLEM YET. yES IT HAS ZINC.
mopar1962 07-01-2009 04:25 AM
penn is ok,why not just buy it from advance auto.Its called kendall racing oil. yes it has zinc,cheaper too. penn bought the kendall brand.Alcohol injected cant beat the 20w50 vr1 with zinc for $3.89 a quart.Hope this helps.
