-   -   BROKEN GLIDE (https://www.racingjunk.com/forums/showthread.php?t=24287)
et7333 05-17-2009 09:11 PM
BROKEN GLIDE
Today I left the line,car shifted into high then acted like it went into neutral and motor hit the hi side chip.I went to pull out of the groove and then the car started to lock the rear tires,then just coasted.I have no low,high or reverse,just park.Did it break the planetary?Stock 1.76 with a couple thousand runs,but trans just rebuilt 170 runs ago.Any idea on what broke?
us7race 05-18-2009 02:05 AM
If the planetaries broke you wouldn't have Park either...
At least that is what mine did when they broke.
et7333 05-18-2009 06:12 AM
I just removed pan and it is clean and so is the filter.Nothing unusual in pan,so is it convertor or??
fla1976 05-18-2009 01:05 PM
PG
You may have broken the front pump. It's easy to check, just pull it out and check the gears. I broke one and it felt like you put it in neutral. Relatively easy fix.
onedragracer 05-18-2009 03:08 PM
Check the input shaft, it's probably broken
et7333 05-19-2009 05:04 PM
Pulled trans today and the input is broke and half is stuck in trans.My trans guy thinks the planetary broke,locked up and then broke the input.I'm installing spare tommorrow and will know about trans when Mike tears it down.
FullTimeRacing 05-19-2009 05:57 PM
what dose the car run and how heavy?
et7333 05-19-2009 06:46 PM
[img]http://i144.photobucket.com/albums/r...3/IMG_1493.jpg
10.30'S @ 130....3125 LBS. 383 SBC[/img]
kwkracing 05-23-2009 08:58 PM
I serious doubt the planetary broke causing the input to break. The input shaft just could not handle your weight and power.
chevyfireball 05-24-2009 03:58 AM
I busted an input shaft doing a burnout. Shit happens. Get a bigger shaft.
