-   -   M/T ET Street Radial??? (https://www.racingjunk.com/forums/showthread.php?t=24300)
bbchevy 05-19-2009 10:11 AM
OK,Heres my ?
I have NEVER ran a set of these before,so some HELP with PSI would be Great!
275/60/15 on a 10"Wheel.
The Car is right @ 3100 w/driver,540"BBC,Glide 5500 8",4.86 Gear,Coil-Over Ladderbar,Stock Frt.Suspension w/Drag Shock.
It does have a Brake in the Trans,but this 12 Bolt SCARES THE S#!T Out of ME,so i will Leave on the Converter,2500-3000??Give or Take??
What do you Guys think for Air PRESSURE?12-13psi?
Let me know...............................?
THANKS
G 8)
olds48 06-05-2009 10:51 PM
I know 3 guys running those tires. One has a fox body with a 540 bbc,one has a bolt-on modified ls1 camaro ss,and the other has another fox body mustang with a 408 sbf and a 250 shot running 5.90s in the 1/8. They all run 13-15 psi on stock suspension. Hope this helps.
bbchevy 06-09-2009 03:17 PM
Radials
THANKS OLDS!
I Just S#!TCANNED the Drag Radials,if my Carb makes it Friday,i will get some HITS on the HOOSIER Slicks,31x10.5W's.
Later
G 8)
ARUSSELL 06-10-2009 07:05 AM
Do you have screws or a beadlock?
