-   -   RACING MOTOR FOR THE FIRST TIME (https://www.racingjunk.com/forums/showthread.php?t=24322)
JEFF69Z28 05-20-2009 09:17 AM
MOTOR IS 406 CHEVY,4340 CRANK,6 INCH H-BEAM RODS,JE FLAT TOP PISTONS WITH 2 VALVE RELIEFS MAYBE 11.5 COMP?CAM IS SOLID ROLLER WITH ROLLER LIFTERS AND ROCKERS 260/265 @50,678/688 EXHAUST,SUPER VICTOR INTAKE PORT MATCHED TO AFR 210CC HEADS COMP PORTED,PRO SYSTEMS 840 CFM CARB,MSD6AL IGNITION,8 INCH ATI CONVERTER,4:56 RING&PINION,TURBO 350 28X9X15 INCH SLICKS IN A 86 MONTE CARLO.SHOULD I JUST FLOOR IT OR BABY IT A COUPLE OF TIMES?
FullTimeRacing 05-20-2009 09:20 AM
did you build it to baby?
I would just stomp it !
txhunter69 05-20-2009 09:23 AM
on race cars i would go balls to the wall every time if its gunna break now itll break later but street i would baby it for a while jmo
JEFF69Z28 05-20-2009 09:27 AM
DO YOU THINK THIS COMBO WILL PUT ME IN THE 10.50 TO 10.90 RANGE?
FullTimeRacing 05-20-2009 10:01 AM
what dose it weigh or way :?:
JEFF69Z28 05-20-2009 10:03 AM
3485 WITH DRIVER
FullTimeRacing 05-20-2009 10:08 AM
mine is #3000 with me and I run (depending on the weather)10.70-11.10 running a 360 cid.big roller
I hope the T-350 is built.
JEFF69Z28 05-20-2009 10:11 AM
MY OTHER MOTOR (406) RAN 11.60 WITH A 510 LIFT CAME 10 INCH CONVERTER AND 3.90 GEARS.
FullTimeRacing 05-20-2009 01:28 PM
I have 4.56 & 30in tall tires,T-350(that is now broke) 8) and go through the lights at 7000 rpm.
I think you will need a bigger tire.
Tod74 05-20-2009 01:37 PM
WHY?
